Trim color codes (1 Viewer)
Behind the bar
I need to know the color code for the metalic silver/gray plastic trim on my 97 Emerald Green LX450.
I've searched and found the paint color code (6M1), but don't see the trim color code anywhere.
"Check your door sticker," you say. I can't. Long story. Short version is that my driver's door was just replaced by a body shop with an OEM new door -- no sticker any more. :o
EDIT: I've seen references to 1A6 and UCAA3, but I'm not sure which (or neither) is correct.
Not sure if this helps but is the best I could find.
Thanks. I found that, too. It has the paint codes, but not the trim color codes. :(
Wulf posted a chart of all the color options a couple of years ago, but it, too, doesn't appear to have the trim color codes.
Not sure if the trim color are the same (mine is White), but I have a bottle of OEM touch up paint for the trim some where in the garage. I'll post it once I get home tonight.
Mine is a metallic gray. If your's is similar, I'm interested in the code.
I may just go with the 1A6 (Moonglow Pearl).
The trim color code on mine (a 045 White body color) is C14 (PN 00258-00C14)
It's metallic gray with a hint of tan.
Frank.
UA31 is the metallic gray trim code.
Any Lexus/Toyota dealer can give you this info based off your VIN.
:beer:
I hope he was able to figure this out in the last year and a half
Yup. Line-X'd the sides a year or more ago. Went with the color code for the Moon Gray Pearl, IIRC.
Thanks for posting up the code for future searchers. :)
