TRD Rims; Questions
Rigger
Ramble Tamble
Staff member
s-Moderator
Wyoming
I love what these rims look like. Where can I get them at a reasonable price? Best Cdan can do is $399 each! Are there other sources besides the used market?
And, do these rims come in different widths and backspacings? Or is there only one width/backspace that fits all 200 LC's, Sequoias, and Tundras?
I've done some searching, both here and on the 'net, and I can't seem to find what I need to definitively answer these questions.
Thanks for your help.
Rigger
Toyota in Vancouver, WA is selling them for 250.00 each.
There is only one version with 5x150 bolt pattern:17x8 with +50 offset.
You can find them on eBay. I just saw a full new set offered by a Lexus dealer for $1380 shipped. Just search google for the part number and you should find several options: PTR45-34120
Wait a minute - are we talking about the new TRD Pro 18" rims in black or the 17" Rock Warrior rims?
Sorry fat fingers. $345 each new RW
I sorta messed up. In my original post, I forgot the pic. YEESH!
All, thanks in advance for your advice. I see a set of 5 RW for sale on Craigslist and the price is pretty good. Maybe a little 'too good' so I'm wondering if they are still worth it and what reconditioning options are available for these rims. I like the stock color, but also see some folks going with the blackout PC treatment as well. I've tried searching through all the 200 forums for clues as to what other options, costs, pros/cons I should consider if the wheels do need some tlc.
I've got a 2011 LC with stock rims / cooper discover plus and looking to make the switch to the TRD RW with BFG KO2s.
Lastly, I assume the 5th RW would fit in this setup as a spare with no issue or modification - is that a bad assumption?
Thanks again all - I appreciate your help!
It will fit he spare location after an east/minor trim of metal tube on the mounting chain. Super easy. Just a matter of fitting at he hanging metal tube through the center hole on the wheel. I haven't done mine yet, but it is described in detail on this forum.
I just looked them up on CL, that's a great price. Plus it's a set of 5, so no searching for others to split a set with to get a spare. As long as they are structurally sound, I'd get them. Good luck!
check the part number. there is an older part #PTR45-34070, that supposedly would make clicking noises on the front hubs. Hopefully someone more knowledgable will contribute what the issue was and if it affects 200s. also, ask if the wheels come with the lug nuts and tool. your stock lugs won't work with the RW's.
I was just reading about that. Lots of Tundra guys couldn't solve that, it seems.
If you run MT's you don't hear it because your radio is up loud.
