Hi, I have the same problem with the LX 450, are the cable the same for the Lexus as well ????, do I only tighten the cable or someone did also mention TPS, I am confused![]()
Yep x 2 adjust that cable.Yep cable. I halfa** adjusted mine and have not had any more flare shift issues.
I adjusted the cable and made it more tense. The 'barrel' is out of the black sleeve. The shift is smoother but it still shifts to 3rd way too early when i accelerate slowly. Maybe i'll fine tune the adjustment.
Adjusting the cable should have taken care of the rpm "flare" between 2nd and 3rd.
However, on a 93+, it will *not* affect actual shift points, which are controlled electronically.
Probably need to start looking at shift solenoids on the tranny itself.
Did you try adjusting the throttle position sensor, like I said?
I've got the same 1-2 flare on my '92 80. There was some slack in the transmission throttle cable, but the red boot was pretty much already touching the crimp. I tightened it a couple revolutions of the adjuster nut to take the slack out but not extremely tight. In some cases, is it necessary to throw out the .4-1.5mm recommendations from other mudders and the FSM? I haven't tested it yet, but I'd hate to cause damage to the transmission because of a slightly over-tight throttle cable.
