Hi ih8mud community,
I have 08 sequoia platinum. Its not going into reverse when cold but shifts in drive mode fine. I kept in start and moved down from drive way on flat surface, after transmission fluid temperature reaches to mid level then it shifts into rerverse normally. I started again and workd fine because transmission fluid temp guage was in middle. Do you think it could be due to low transmission fluid? Should i go for transmission flush ? Any help will be appreciated. Thanks
