I am getting ready to put a used H55F into my 40. I'm not planning on rebuilding it but I do want to replace gaskets, seals and front/rear bearings (if necessary).
I pulled the top cover and it looks clean, shfts fine and doesn't seem to make any noise (spinning it by hand).
The input shaft - the shaft that goes from the transmission into the clutch and pilot bearing - has a good amount of wobble to it. I pulled the front bearing retainer and I can move the shaft off axis a good amount.... is this normal/acceptable? Should this shaft be tight? Is this just a matter of replacing the bearing there? If so can I replace it without pulling the shaft itself? I really don't want to tear the tranny apart..
Thanks,
Mark
Thanks,
Mark
