How does this plug work? Do you remove it and let the excess fluid drain until it stops? Do you loosen it a turn or two and let the excess fluid drain until it stops?
It is short. No longer than the drain plug so it seems to me that removing it will drain the transmission.
What is the proper method to check the transmission fluid on a '04 with no dipstick?
