I am not new to Land Cruisers, but new to the 80 series and new to messing with transfer cases other than changing seals and gaskets.
I recently bought a semi rough 1994 Fzj80 with 171k on the clock.
Getting it back to baseline I noticed the drive shafts were not indexed correctly and finally surmised the transfer case has been removed and TIG welded on lower DS flange/case where the bolt goes through holding the front and back halves together.
I do not know the original reasons for the PO taking it out or how the case was broken, I suspect it was leaking and the mechanic broke the case. Anyhow it is a good TIG weld and is not an issue. The nose cone seals are new and there is some orange RTV coming out of the mating faces.
From inside I moved the transfer case shifter to the L position and the CDL/ABS lights illuminated as they should. As I start to move the vehicle forward (yes it is in the lower gears) the shifter pops forward and the transfer case goes to neutral... I can hold the shifter in the L position but can feel it wants to continue to jump out....
After searching and searching I cant find anyone else having this issue.
One thread indicates adjusting the shifter rod from the shifter to the transfer case shifter coming out of the transfer case by loosening the 12 mm nut and moving it some.
I tried it in a few different locations, but only the original location got me to start the engine and be in H gear...there is not enough adjustment slot to put it where I think it needs to be.
BUT, when I disconnected the shifter linkage rod from the transfer shift lever on the case and move it there are distinctive detent/dimple/catches for H and N, but after the N spot there are 4 more detents where I would imagine there should be just one for L...... it is almost like the transfer High/Low shaft has more dentents than it is supposed to, or the inner transfer shift lever is installed incorrectly....
Anyone have any ideas what to do to fix this? What is causing this?
