While you’re at it, replace the seal in the sleeve (9031009001) and the o-ring (9671124030) that fits around the body of the sleeve sub-assembly. Also, before you order, check the driven gear and consider replacing that as well. This is a really straightforward job, except for maybe getting the seal out of the bore which takes a bit of cajoling to pull the old seal out. Try not to mar the bore in the sleeve s/a if you do choose to replace the seal.
Go slowly and do post if you need anything else!
Also, go easy on the collar that threads down onto the transfer case if it’s more than finger tight and needs some persuasion from slip joints or something.
