kiwidog
Kiwidog
TC in neutral towing
I think Poser is right there are only four bolts to safety.
However it is probably not necessary to remove the rear drive shaft if you have 2WD neutral.
The bushing in the high/low output gears don't seem to get worn out by turning they get worn out from not turning.
Counterintuitive but thats what seems to happen.
I just replace the bushing on the high speed gear which doesn't turn on the output shaft in high range it turns with it. The low range gear turns on the shaft all the time you are in high range and it doesn't get worn out from turning. This assuming you drive in high range more than low range. As an aside. My 1980 FJ40 has been in low range for the last 20 years 95% of the time. That is it's an unregistered farm trail 40 and snow plow
So if you flat tow in 2WD neutral the output shaft turns in both bushings which is good if you believe that the bushing are worn out from not turning on the output rather than turning.
If it was mine and I was towing it 30 or 40 miles I wouldn't take the rear shaft off. However if it was 100 miles I would remove the shaft just for the peace of mind I didn't leave the TC and transmission in gear.
See post pictures of the worn high speed gear bushing in a one piece TC
https://forum.ih8mud.com/40-55-seri...ing-bushing-high-speed-gear-one-piece-tc.html
Just another opinion
Thanks jb
Thanks jb
