Tranny Sounds
Magnolia, TX
I finally got the carb workin, BUT now there is a new sound coming from the transmission!!!
when it is running there are "wooshing" and "gargaling" sounds comeing from the tranny and when i drove it around the block when i would press the clutch to shift it made a sound like pressure being released.
so now what could it be???!!!
HELP!!!!
lately it seems like everything is falling apart on the cruiser.
any ideas???
i checked all fluids and there are fine. the thing that i dont get is it is making noised but it all still works fine.
Get an automotive stethoscope, but the rear on jackstands, get someone else to start it up & go through the gears, & poke around underneath until you find it. I second 60wag - whooshing & gargling sound like air in the cooling system.
Noises when you disengage the clutch probably have to do with it (mc & slave cylinder, throwout bearing).
QUOTE]
i thought the same but when i went under the cruiser you can defintly hear the sounds coming out from the tranny
