tranny cooler installation??
Forget the tranny cooler let's install a kegerator. That'll keep everything COOL !
Tonkota- Any pics of where you cut the stock lines? We weren't sure whether it would be easier to cut the lines further away from the stock cooler or closer to the radiator where they're braided.
tonkota said:
It's pretty easy to do. The flow of fluid runs into the drivers side of the rad then out the passenger side, cut the line here, after it comes out of the stock cooler. Here is a picture of mine that I just did a couple months ago.
http://www.steelnthings.com/landcruiser/transmission/cooler.jpg
if you have any pics of where you cut into the return like i'd really appreciate em
thanks
-nate :beer:
I don't think I cut any lines to install my tranny cooler. I unhooked the return line from radiator and routed a new line from there to the tranny cooler and then a new line from the tranny cooler back to the line that was formally connected to the radiator. When I did mine it was kind of a rush job and was going to go back a clean it up later (it really wasn't that bad), but never have. I would take a picture for you but I as still living in the early '90s and do not have a digital camera.
this hepls alot.
me too, this one thing has been holding me up for the last few weeks, i have to take out my transfer case soon, so when i do that i'll take out the return like and have a pair of fittings made to match and just make a new hose to run from the radiator to the cooler and leave all origional in tact, but i have a feeling this won't be as easy as it sounds
No pics, sorry. I did cut them pretty close to the rad though. Right next to the 45 degree cross brace. I used a utility knife. Easy as cutting apple pie.
Routing the lines through the sheet metal took more time and care.
mpetersrx7 is right. I just did this a couple of weeks ago. Just cut the cover off the fitting not damaging the tapered end of the fitting. then pull it out of the stock toyota hose. Then put it into the new hose and hose clamp it and you have a toyota fitting on any hose.
Andrew
Hell the best part is I did not even have to remove the hose first. I was having trouble trying to get it off, so I just took the dremel to it and perfect. Plus now it is real easy to do a passive flush or remove fluid. =)
Andrew
