Living in the Past
Checking out the wiring on my 4Runner I found only the tail lights wire on the OEM four pin plug. Since the tail lights have separate turn signal/brake lights there has to be a convertor. Wiring heads towards the driver's side. The cargo area does not have a excess panel on that side. Figured there would be a opening behind the tail light but they isn't. Neither the of the fuse panel show a fuse for trailer lights. Years ago I added a trailer hitch to a 2001 Tundra. I was able to buy everything from Toyota for the wiring. By the battery I added a short wire and fuse holder that supplied power for the lights. Then the convertor in the back that took a signal from the rear lights. Not finding either on this 4Runner. I have the build sheet and the trailer hitch was installed by Toyota. Anyone know where the convertor is or which fuses to check? I didn't see any link available anymore for FSMs. Really don't want to spent hundreds of dollars for them. Any aftermarket manuals (Haynes/Chiltons) worth buying?
