I have a terrible creaking and popping from what seems to be the front right wheel well. I can bounce the car to replicate the creaking, and the popping seems to happen when the weight transfers from side to side, typically when loading the right side. Everything in the front suspension is new within the last two years outside of the shocks, but I removed the shocks and the noise remains. I also disconnected the sway bar and it remained. The steering rack and bushings were replaced last year and everything is tight there. I've done a lot of self diagnosis and had two shops look at it... no one can figure it out.
The last and seemingly more competent shop suggested body mounts could be the culprit. Does that sounds like a possibility? How would I test that theory? Thinking about trying to wedge some wood between body and frame to see if the noise changes.
What else should I take a look at?
Thanks!
Thanks!
