TPS and APPS part numbers needed please
Hi Guys,
Trying to find the parts numbers for the Throttle position sensor and the APPS, can't find them on toyodiy.com and the dealer says i have to buy the throttle body for 800 bucks to get the tps???? Doesn't make sense to me - or do I just buy after market?
I'm showing VSC off VSC TRAC and engine light, truck is down on power - was intermittent now it is constant. I figured I'd try the TPS first then the APPS - unless someone tells me to just change out the APPS.
Thanks!
Louis
PS, sounds like I get to make another repair tutorial!
Hi Guys,
Thanks!
Louis
Why year is your truck? Try toyotapartszone.com
ok, don't need it! A squirrel packed my air box full of pine cones! I had only just changed the filter a couple of days ago and there was nothing in there, the little bastard.
Should run fine now.
Thanks guys!
I was just going to say... I don't think I've heard of any 03-07 having a TPS/APPS problems. It was an improved set-up over the 98-02.
That's great you figured it out before spending the $$.
Nice squirrel restriction.
check this out - just the way i found it.
Haaaaaa. That is too funny. Boy that really is restricted isn't it?
You've got to be kidding!
You're lucky you don't have a K&N... some of those are small enough to have made it through the porous foam... :flipoff2:
In other news... what's up with all that oil residue on the fender side of the intake?
