I have a used Speed Density setup that was taken off of a YJ w/ a SBC 305 in it. The rig was converted to propane and everything was working when removed.
I have a complete harness from painless that is specifically for the MAP speed density systems. This is for a TPI that doesn't use a MAF sensor before the throttle body.
I also have the ECM that was used along with the chip that was running in the YJ.
I will sell everything for $175 shipped in the lower 48.
Just the harness alone is over $250, plus $100 for a used ECM and another $100 for the chip. That's $275 less than scrounging it up yourself. Pics can be sent via email.
The harness is in perfect shape. All original plugs are there. The only bare wires are for the ignition, ground, starter, brake switch, A/C power, and VSS.
The chip had VATS removed and is setup for a 305 with a VSS and knock sensor.
Here are a few pics:
