RufusTheDufus
Edited on May 25th, 2021 to add: I'm no longer making these compression test adapters.
I have been working on a compression test adapter for the 13B-T engine. This is a replacement/substitute for Toyota SST 09992-00023 Gauge Adapter. I have a final prototype in-hand now and am happy with the way it came out. So I plan to start selling them very soon.
This is an adapter that you would use with your own diesel engine compression test gauge. It comes tapped with either 1/8" NPT threads or 1/4" NPT threads for you to connect it to your tester's hose and quick connects. There's a Schrader valve in the cylinder end to ensure the adapter and gauge doesn't add any volume to the compression chamber.
These are CNC machined from steel bar stock. I have to run them in batches of 12 to be cost effective for materials and machine time. It takes about 34 minutes on the CNC lathe to completely finish a single part.
Accepting pre-orders on the first batch of 12 at $69/each just to get them out there. After that the price will go to $89.
Edited on Sept 9th 2014 to add: verified that this adapter works with the 12H-T engine as well.
