For Sale Toyota OEM Oil Pan FJ40 2F
Atlanta, GA
Pulled this from my US spec 1981 FJ40 and is all original and just needs a good clean. Has about 140k miles on the pan and had a very small small oil drip either between bash plate mounting point, or the drain plug or from oil gasket itself (PO used horrendous gasket sealant as you can see). Used dye to pinpoint where (see UV pics below) and a smear of FIPG on oil plug. Mounting flanges are straight but selling for cheap price for someone can can easily identify and fix. Comes with OEM oil plug and several oil plug fiber gaskets for free.
Asking $75 obo + shipping to you from Marietta, GA 30062. Sold as is.
Over forty years ago caught the bash plate on the oil pan in my 68 when installing the engine. Created a leak at a spot weld between the oil pan and bash plate. Brazed the area on the inside and it has never leaked again. Back right on the bash plate has a larger gap. Possible it did the same to yours at some point. Should be an easy fix if that's the case.
GLWS
Not really much of a market for used oil pans considering the cost of shipping alone can approach the price of a new OEM one
