For Sale Toyota LandCruiser HJ61 $20000 CAN
  1. 60 Series
Vancouver, British Columbia Canada
Recent Service History:
- Differential Oil Changed
- Knuckled Rebuild
- Brake Fluid Change
- Replaced Rear sway bar and bushings
- Alternator Checked – Output is good
- Crank Seal replaced
- Air filter
- new brake rotors and pads
- Synthetic oil changes performed religiously every 5,000 Kms
- Air filter replaced every 10,000 Kms
Upgrades
Transmission:
- A440F
- Equipped with Extreme Valve Body featuring 3rd & 4th Gear Lockup
- Transmission Cooler
- Rebuilt HD Torque Converter at TCS in Langley, incorporating heavy-duty linings, optimized veins, and a lowered stall speed of 200rpm
Turbo:
- Ct26 precision machined and enhanced with a larger wheel
Intercooler:
- Enhanced with 2.25” Piping
- Equipped with HKS 2.5” Intercooler
- Hallman Boost Controller for precise performance
- Reduced post-turbo temperatures by nearly 200 degrees F
Engine:
And more, however not enough space here to type it
Any more question plz msg
Cable lockers? Interior pics? Odometer reading?
Unfortunately, no cable lockers.
Since I took this odometer reading drove it a bit. I will have to go to my storage and take a new picture of the reading. It doesn’t have much more than this.
Hey man, awesome vehicle. I was wondering if you had some pics of the engine and underside of the car. Just wondering about the rust situation.
Thanks!
That back problem is the only real problem for rust
As far as the underside, there’s only surface rust nothing on the frame
Thanks for the extra information. Im gonna review the pics and details with my brother but Im super interested. I live in Ontario so if I did buy it I'd have to fly out and pick it up and drive it to where I live. Do you reckon based on its current state I could manage that or would I need to do some maintenance before that long trip
all the maintenance is up-to-date and it will not need anything prior to the drive currently has a leaking valve stem in one of the wheels but I’m getting that fixed this week
6049106678
Feel free to give me a call
