ARCHIVE Toyota Gear Packages - Just Differentials
Cashmere WA
Website
www.justdifferentials.com
At Just Differentials we carry gear and axle accessories for nearly every vehicle out there. We work on developing and stocking the hard to find parts, or gear sets, so you can make one call to find everything you need to repair or replace parts in your axles.
Our Gear Packages include everything you need to regear both your front and rear axles with high quality parts. They include Front and Rear:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
Check out all of our Toyota gear packages below. We have gear sets for many more vehicles then are listed on our website. If you need a quote or have a question, send us an email or call us at the number listed below. We only made a small number of our gear sets into packages with a single part number. So if you don't see your vehicle, don't worry, we can still help you out. Just give us a call or email us and we will take care of you!
1991-1997 Toyota Land Cruiser 70 & 80 Series Front & Rear Gear Package Kit:
4.56
4.56 with OE lockers
4.88
4.88 with OE lockers
5.29
5.29 with OE lockers
1998-2007 Toyota Landcruiser 100 Series Front & Rear Gear Package Kit:
4.30
4.30 with oe rear locker
4.88
4.88 with oe rear locker
2008-Present Toyota Land Cruiser 200 Series Front & Rear Gear Package Kit:
4.88
Toyota Landcruiser II, Bundera LJ, RJ, KZJ 70/73/78 Front & Rear Gear Package Kit:
4.30
4.56
4.88
5.29
07-09 FJ Cruiser, 03-09 4Runner Prado 120, 05+ Hilux Front & Rear Gear Package Kit:
4.56
4.56 with OE rear locker
4.88
4.88 with OE rear locker
2010+ FJ Cruiser, 4runner, Prado 150 Front & Rear Gear Package Kit:
4.56
95.5-04 Tacoma, 00-06 Tundra & Sequoia Front & Rear Gear Package Kit:
4.56 without Rear locker
4.88 without Rear Locker
5.29 without rear locker
05+ Tacoma Front & Rear Gear Package Kit:
4.56
4.88
4.88 with OE rear Locker
07+ Toyota Tundra Front & Rear Gear Package Kit:
4.88 w/ 5.7L
4.88 w/ 4.6L or 4.7L
If you need a quote, either EMAIL or CALL us: 866 525 4620
Just picked up some locked thirds from Nitro. Everything came complete and was ready to install. Finishing up the break in period over the next week or so. Thanks @just differentials
We keep our gear package kits in stock and ready to ship out to you! If you have any questions let us know. If you don't see the options you are looking for, give us a call at 866 349 6801 or email us info@justdifferentials.com. Check out all our gear package kits online:
Overlanding.
I don't need to regear, my tires are only a little bigger than stock.
It's a common statement and one we enjoy addressing when the opportunity presents itself. Overland preparation tends to add weight to the base vehicle. Bumpers, winches, skidplates and tire carriers can add a tremendous amount of weight from stock. Add a rooftop tent or rack assembly up high and aerodynamic drag is greatly increased as well further reducing performance both on and off-road.
Beyond increased weight, vehicle manufacturers almost always opt for a borderline gear ratio from the factory to optimize unloaded fuel economy. This means that even running near stock size tires, a heavily loaded, taller than stock and factory undergeared Overland 4x4 is a very poor performing machine both in terms of acceleration and fuel economy. This reduces cross country fuel range, on road responsiveness and off-road control all at the same time.
The solution is regearing. Proper gear ratios put the engine at optimum RPM for performance and fuel economy and give you the opportunity to add traction aiding differentials during gear installation greatly enhancing the capability of your backcountry 4x4 in the field, on the highway and around town.
Just Differentials is the leader with gear packages available for all the common Overlanding platforms. These kits include ring and pinions, full master setup parts and everything your mechanic needs to regear your rig and make it function as it should instead of gasping every time you climb a mild grade.
Call us at 866-349-6801 or check out our package options here.
