Just curious, what is the point of Toyota's accessory front skid plate? Does this imply that the skidplate already there is inadequate, or is it because the aluminum plate "looks good"? Does the front end take more abuse? Thanks.
Weedo said:I put on the Skidplate myself and it appears to be a very heavy duty piece. Its definitely vulnerable underneath of there until you put a plate on. It was, what, $200? I've already scraped it running up rocks. I wouldn't have wanted to tear up that part of the truck without it...
I dont' think it is as heavy duty as it could be, but it's fine for what I need.
TexasBadlands said:Either I find time to break out the torch and welder to fab my own up, or I wait til some nice aftermarket plates come out. Either way, it's going to cost us all more money. Toyota should have done it right so we didn't have to spend more money.
Weedo said:So in all your hardcore wheelin' with your FJ... what have you found that the skid plate is lacking in?? I think sometimes people are too quick to dismiss something before they've REALLY tried it (not saying this about you, just a comment).
woody said:I run a piece of 3/8" 6061 alum for my skid plate on my offroad rig....I use it VERY hard, and have supported much of the rig on it before....supported only by the frame rails.
I know quite a few other hardcore wheelers who run 1/4" alum skids with no problems either, but they frequently support on 4 sides where mine is only attached to the frame rails.
For front protection for 95% of owners, the 3/16" will be perfect in front....the 5% of us who will push the rig well past it's expected limits will likely spring for a true aftermarket option, like what AllPro does with their bumper.
My next rig will be running 6061 1/4" skids and 7075-T6 alum links too![]()
The accessory skid plate from Toyota for the FJC can support ~1,000 lbs. I'll probably be getting one, if for nothing else than because it's a pretty good pattern to make my own plate.woody said:I run a piece of 3/8" 6061 alum for my skid plate on my offroad rig....I use it VERY hard, and have supported much of the rig on it before....supported only by the frame rails.
