Toy IFS Hubs as wheel spacers??
Josie'sLandCruiser
Stop calling it a "FJ."
Seattle, USA
Hi All:
I vaguely remember hearing about folks using the front axle hubs from a IFS Toyota 4wd pick-up on Toyota solid front axles. Seems the IFS hubs are wider, acting as a wheel spacer on the solid axle? Any truth to this? Anyone have any info or links??
Thanks much!
Alan
checkout the FAQ
looks like wheel profile may be an issue...
Hi All:
Thanks Manny, I had already spent some time on Pir*ate reading.
Mace, thanks for the link to SKY - I could seem to find them using Google. :rolleyes:
Regards,
Alan
Several years ago it was front range offroad that made the adapter plate to the use the IFS bearings hubs on a solid axle. Was basically a 3" spacer.
I'll be doing mine similar to the picture above, except using a rotor from a 4x4 Tacoma. Instead of mounting the rotor to the back of the hub like shown, the Tacoma rotor allows you to have a drop off rotor setup. I had to machine the ears slightly on the IFS hub where the wheel studs go, but everything bolts right up with the caliper on the outside of the knuckle ear. I don't have pictures yet since I haven't had time to work on it lately.
that sounds interesting .. it means something like a floating disc . ?
