Thanks, I had to run 2 wires for the 12v lead and brakes.
Following. Looking forward to an update.I thought I would add this here since I searched the board extensively when looking for a travel trailer.
This is a 25.75’ trailer that is 5,008 lbs unloaded and has a 660 lb tongue weight (listed, measure @ 700 lbs when trailer unloaded). I only installed the Timbren bump stops, not airbags, and truck is pretty level and AHC works fine so far (haven’t made a loaded trip yet but will update this if anything changes). The WD hitch is a ProPride 3p and May be overkill but I wanted no sway given the short wheelbase of the truck and being at limits. Gas mileage appears to be 7 mpg, worse or equal to a gas 35’ class A we had when towing a car behind it. Oh well. Only for shortish trips and occasional getaways.
What are your thoughts on the Clearview mirrors? Was thinking of potentially doing them down the road, lots of good reviews elsewhere in the world but not much US.I have stock AHC and rear bags. 25 PSI with unloaded 16×8 trailer (3000 lbs) as well as Curt BT brake controller, Husky WD/AS hitch, battery backup trailer break-away switch, and Clearview tow mirrors.
At full extension, I can BARELY see down the side of my 16×8 trailer. Another six inches would make a huge difference (that's what she said!). The curved portion is also really helpful to eliminate the blind spots at all times. The curved glass is adjusted by hand, no power adjustment is possible. No heating element, no wiring for turn signal. If your load is 8ft wide they are priceless. They are also probably very useful for 7ft wide loads and thinner, but maybe not necessary. When it comes to towing in my book, safety first.What are your thoughts on the Clearview mirrors? Was thinking of potentially doing them down the road, lots of good reviews elsewhere in the world but not much US.
Interesting... So not sure on dimensions but we are looking at purchasing a travel trailer in the near future. We borrowed a family members a couple years ago and towed with our stock '11 4Runner and the stock mirrors could just barely see down the length of the trailer (basically as wide as the vehicle was). So was curious as to whether these offered any sort of advantages over the cheap strap on types?At full extension, I can BARELY see down the side of my 16×8 trailer. Another six inches would make a huge difference (that's what she said!). The curved portion is also really helpful to eliminate the blind spots at all times. The curved glass is adjusted by hand, no power adjustment is possible. No heating element, no wiring for turn signal. If your load is 8ft wide they are priceless. They are also probably very useful for 7ft wide loads and thinner, but maybe not necessary. When it comes to towing in my book, safety first.
Well, they don't collapse at highway speed and the main glass is power adjustable. Plus, their rarity in the US should make them easier to sell if that needs to happen.Interesting... So not sure on dimensions but we are looking at purchasing a travel trailer in the near future. We borrowed a family members a couple years ago and towed with our stock '11 4Runner and the stock mirrors could just barely see down the length of the trailer (basically as wide as the vehicle was). So was curious as to whether these offered any sort of advantages over the cheap strap on types?
Yeah that is exactly what has kept me from buying them. I need to test out my ones that we purchased for the 4Runner to see if they do the same thing. Maybe come up with some rope/line contraption that ties to the fender to keep the driver side from collapsing if so.I do like the clearviews, but Damn, $550.
Nice set up, we have the smaller version (172). Did you tow with O/D off or on on the flat roads?Pulled our Rpod 180 with our 2002 LX470 from central NC to Cherokee, NC.
6% grade for 5 miles on I-40 - curvy but 3 lanes.
I was not the slowest - did pass some 18 wheeler's.
4-speed Transmission.
Tekonsha P3 Brake Controller mounted in ash tray, Draw-Tite 7509S Hitch, Equalizer 0600 hitch (weight distribution, and sway).
Had to use 2-cd gear up and back down mountain.
Also faced a 9% grade on Hwy US 19.
Surprised that I got 12mpg - but I keep my speed at 60mph on flat roads.
Before I made this trip, I was really concerned, but after doing it I feel pretty good about my LX470.
Thank you cwmoser, I tried o/d on for a bit on the flat roads, felt good. I had to watch the switching as we got on inclines, the transition between gears def got a bit rougher. We pulled ours from SC to Maine this summer. Went the long was through WV, Western PA, NY, VA to Lakeville, ME. (4 days on the road) On the way back we went to NJ for a week, and then straight through to SC (one day of driving each day for those trips).On flat roads I tow our Rpod with Over Drive On.
On approach to inclines I do switch it off.
