Torsion Bar And Front Grille
Philippines
What Is The Correct Procedure To Adjust The Torsion Bar To Attain The Height That I Want? I Went To An Alignment Shop And Crank The T-bar Down To 30.5inches From Wheel Well To The Lip Of The 18 Inch Wheel Below. Went Home And Check And The Driver Side Was Lower Than 30.5 Inches Passenger Side Was Ok. Isn't That The Driver Side Should Be A Little Bit Higher? Any Help Would Be Appreciated! Has Anyone Selling Front Grille Of 1998-2002? Mint Condition And Less Than $100 Only. Pm Me Please.
Look in the 100 tech under the OME T bar installation. Both sides should be the same and the height really should be not what you want but what is good for the susoension i.e. you need to have a min droop of X.
