For Sale Toronto CA: 1988 LANDCRUISER VX HJ61 12h-t turbo Diesel. 24 volt 5 Speed Manual. Power brakes, Air Conditioning, Power Windows & Locks.
Year
1988
  1. 60 Series
Mileage
187114
Color
hsl(0, 1%, 48%)
$95,000.00 CAD + $4000.00 parts
Pictures: Landcruiser Pictures - Google Drive - https://drive.google.com/drive/folders/1-32TvLjzsBTwuC-VMZdFv7xqV4EtG3O_
HISTORY
This Land Cruiser lived most of its life in a very dry climate in Malaga Spain.
A Landcruiser enthusiast was the second owner in Malaga Spain who purchased it from the original owner. He sold the Land Cruiser in October 2012 to me and imported it to Toronto Canada.
Since then this Land Cruiser has always been stored inside a garage.
On arrival to Canada the Land Cruiser had the original paint on it from the bottom of the windows to the roof. The rest of the truck was in primer. It had 234,000 km. Now 301,130km
FULL REPAINT
In the spring of 2013 it had a complete paint job done (everything was removed) after stripping to bare metal, dents were pulled , ready for a thin layer of Bondo, primed with apoxy primer then primer surfacer then block sanded several times.
The best seam sealer was applied in ALL the seams.
Paint colour outside is magnetic metallic grey, base coat clear coat.
After the paint was completed it was oil sprayed with Krown EACH YEAR in all the panels and undercarriage.
I have all the maintenance records.
NAPA AUTOPRO - Dave Versteegh Auto Repair Inc.
Dave’s Mechanical shop performed much of the major repairs and maintenance.
MAINTENANCE & UPGRADES
  • Original Copper rad was fitted with a new 4 Core Radiator in 2015. Will never overheat in Hot temperatures all day long.
  • Just installed a New Water Pump and all new factory hoses and clamps + cooling system flush completed July 2025
  • Original Driver/Passenger Suspension seats
  • Custom Front 1/4” Steel Winch Bumper and Custom Rear 1/4” Steel Bumper with Rear Swing Spare and Jack Holder, Heavy Duty Rear Hitch.
  • Baja Design S1 On/Off Switched Daytime Running Lights
  • 4 JW Seaker 8800 Evolution LED head lights. Still have Original Halogen Head Lights
  • 2 - 24V to 12V Converters.
  • Second Skin Damplifier Pro sound deadening mat throughout the floor.
  • Custom Rock sliders welded to the frame. Very Strong. Can hold weight of truck.
  • 12” Offset DuraFlap mud flaps 3/8 Polyethylene/Rubber Blend, Aluminum high gloss weight's
  • Wabesto diesel heater. Heats up engine to 140 degrees. Heater can warm the inside truck without the truck running.
  • Kenwood double din DDX9906XR Excelon Refrence DVD Receiver.
  • JL Audio MHD900/5-24 VOLT 5 Ch. 900W Amplifier. 100W x 4 main channels 500W x 1 Subwoofer.
  • 2 Focal KRX2 Power series 6.5” 2 way Component Speaker system.
  • 2 Infinity 6.5” 2 way speakers in the rear. 2 JL Audio 6W3v3-4 6.5" Subwoofers
  • Updated Positive and Negative battery Cables replaced by QuickCable.com
  • 2 NorthStar AGM Batteries. Purchased May 2017. Batteries constantly maintained.
  • Dual Bank On-Board ProMarinor Battery Charger
  • Blue Sea 24V Custom 5 30 Amp Relay Fuse Panel to add Accessories.
  • Blue Sea Systems Voltmeter monitors each battery. USB 12 Volt Charger, 12 Volt Socket Charger.
  • Autometer mechanical Oil Pressure & Water Temperature Gauges
  • Rear Cargo Powerful LED Light
  • 4 Jet Black Stealth Custom Series Rims 17x9 OFFSET -38MM.
  • 4 Toyo Open Country M/T 33x12.5R17/10
  • Air Horn.
EXTRA PARTS priced separately. Worth more than $8000.00 if purchased separately
Rebuilt 24V Alternator with vacuum pump.
Starter, Power Steering Pump, Front Wiper Motor.
All glass EXCEPT front windshield, Front and rear drive shaft. Box full of Toyota relays, and other electrical components.
2 Power window motors, 6 Lock solenoids, Front & Rear blower motor.
2 Rear wheel bearings. 24 Volt Tac, Steering wheel, Vacuum brake.
4 Original Toyota 16x6 White steel rims. Original senter Console.
Original H55F 5 Speed manual transmission. The previous owner said it only needs a center bearing.
Many more parts not listed but are shown in pictures.
