will see what brakes first!
You keeping the hood on?
Took the 40 out for a pre FG shakedown cruise and noticed it was handling awful after a short run through a rocky trail.
When I got home, I jacked it up and got the weight off the axles. I was wobbling the tires back and forth and turning the steering wheel back and forth and there was a lot of slop and a clunk at each end. Turns out the center arm pivot housing had 2 loose bolts and a third bolt loose because the welded nut had broken off the inside of the frame cross member. On top of that, the rod end on the center arm was loose and wobbling back and forth.
It wouldn't have taken much more wheeling for the whiole thing to come loose and lose all steering control. On the trail that would have been bad, but on the highway it might have been deadly.
I was able to tighten the pivot housing back up without any problem. I will put checking those bolts on my inspection list from now on along with u-bolts. (Last year I discovered my rear u-bolts were all loose enough for the axle to rotate slightly.)
I tightened up the rod end and the slop there is gone. There was some wear on the rod end shaft, so I ordered a new one. I should have it Tuesday. I went aftermarket, only $25, liftetime warranty. The local stealer wanted $105 after discounting, that's a sin!
I also noticed my brake pedal was low and I could only get the fronts to lock up on a dirt road. I figured the rears needed adjusting. More unhappy discoveries. Not only were drums in the rear filled with caked on dried mud, but the innards were pretty rusty and the shoes are getting thin.
When I step on the brake, only the back cylinder on the left rear wheel activates momentarily. It moves the shoe and then collapses again. The front cylinder on that side doesn't move a millimeter. My wife is away, so I have no way to see if the right rear cylinders are working. I imagine not.
I bled the lines, but no change. It isn't leaking on either side. I ordered hardware kits and shoes, Tuesday arrival again. New aftermarket wheel cylinders are $200, twice that for the Toyota ones. I'm going to get the kits and rebuild my own. I should be able to refresh the rear brake system for $100, a lot cheaper than dropping $360 into them or converting to disks for $450. If my plan was to keep the truck long term, I would do the disk brake route.
Based on the lack of motion at the rear cylinders, I'm thinking my master may be on its way out. If that turns out to be the case, I doubt the 40 will be at this year's Fall Gathering. I was going to tow it over behind the FJC, but now it may still be on jackstands when I leave on Thursday.
Whoever buys it may wind up with a nice new braking system, at least the rears and possibly master. The fronts were already done awhile back.
Has anyone come up with a way to flush out the rear brake drum assembly after wheeling in mud short of pulling the wheels and drums?
don't go in mud?
Sorry it was thought of Bob wheeling his outbackGlad I gave you a good laugh.
