Obviously in a normal healthy-ish car the answer is always drain and refill with new oil.
But what about the beat up units, or the ones you have no idea the history about?
Where I come from every seems to oppose changing these oils (manual transmission, Diffs, transfer case). And especially on older cars. The "procedure" is to add oil if not enough. At least when it comes to older cars everyone agrees with this, owners and mechanics!
Recently I replaced the front Axle seals on my 1991 FJ70 because it was leaking since I got it. I filled everything with 140w oil as the mechanic's recommendation (hot climate etc). Interestingly the rear diff was almost dry, with no leaks visible.
I have no symptoms with this drive train except moving the shifter front Lo back to high is difficult.
Is the above mentioned belief correct in any way? If I drained and filled this oil in an old diff/trans/Tcase am I going to harm it or start to have symptoms?
(is 140w way too heavy even for a hot climate?)
EDIT: I'm willing to bet the oils in this car have never been changed since it came out of the factory. Maybe previous owners just added oil as they went along. Car has 274k km almost.
