light_duty said:The HZJ77 has the same tail light issues as the LJ78, i.e. no DOT/SAE markings.
Finally, I'm not sure I'd describe the 2L-TE as anemic, but it's certainly no bottle rocket. Mine is quite happy to sit at 100 on the highway, but the EGTs rise as quickly as the speed drops on hillls. It will be remarkably similar to your diesel VW. Off-road, though, the available torque feels limitless - if I'm not mistaken the engine is rated at 179 ft/lbs of torque.
I'm a fan of the 2L-TE, despite having to replace the cylinder head on mine. But I'm definitely in the minority on this board, and I respectfully defer to the collective expertise here. Still, there are some who knock the engine without having tried it. All I can say is it works for me!
Robin
Stone said:IRC, the HZJ77 has the same tail lights as the other HD 70 series and consequently have the correct DOT markings on them. The LD LJ78 on the other hand have a slightly different tail light that are not interchangeable with the HD for some reason. But...this is just third hand info and I could very well be wrong.
denis said:The body being absolutely identical, I would bet a lot on you very well being wrong![]()
The issue doesn't seem to have been raised as much for the HZ series because they are less numerous.
