Getting my lift on Monday - 2.5" OME. It's between the 285 or the 315's. I like the idea of the 315, but what are some disadvantages of the larger tire? Is there rubbing when turning? Any and all advice is welcome. Thanks.
You chose the wrong lift if you were considering 35" tires.
... You chose the wrong lift if you were considering 35" tires.
How in the world is your 285's nearly ripping a flare off?? There should be zero contact unless your bump stops are worn or you have some axle misalingment.
The whole argumet to run 35s should be based on:
1. How much rubbing is acceptable for the individual
2. How much bump stop lowering will be needed to satisfy that individual.
3. How much wheel travel will be left after said stop lowering vs. the amount of lift
If the individual doesn't care about rubbing and flares etc. are removed then it's possible to run with no bump stop modification. In that case a stock lift is perfectly acceptable. SO AGAIN I say go search, read what's been talked to death about and make YOUR own descision to what is acceptable.
