Installed 4 new tires on 99 LC they are AT's, 600 miles on new set 3 are wearing even and the one on the passenger side rear is starting a saw tooth pattern on the very outer edge. must be alignment? Is the LC 4 wheel alignment? If so does anyone know the correct alignment spec's for a 99? Would like to know so when I take it in Friday I can give them the correct spec's. If not alignment what do you think could be causing this problem?
Thanks
Thanks
