e9999 said:OK, I may just give it a try then.
The anchoring 'll be a pain, though... gotta think of something that thewon't object to...
if you mean pickup when you say big truck, yes. tractor trailer is big truck to me and i doubt ite9999 said:so this thing works OK for big truck tires too, then?
not if you run centramatics or some other self balancer.MoJ said:I'd think it would be good for dismounting but wouldn't you still have to visit the tire shop to get everything balanced? Oh well, for 35 bucks it probably doesn't matter much anyway. Let us know how it works!
e9999 said:what'a good lube to use that I would likely have around the shop? soap? detergent and water?
, yeah soap or detergent and water works great.e9999 said:also, I don't plan to balance the trailer tires
reffug said:money saved
tires worn early = money spent.![]()
e9999 said:and how does balancing a tire or not affect wear, exactly?
NorCalDoug said:Is this a serious question?
try googling "tire wear unbalanced"
e9999 said:if you're talking about cupping, I don't know that this is a significant issue on a small trailer tire like mine. Do you see any weights on your popup wheels? Mine don't have any from the factory. It doesn't look like they were balanced in the first place. And it looks like my tires will wear from high pressure and camber issues before I have to worry about cupping etc...
tfdcruiser said:I have used it to change very expensive mag wheels and chrome wheels. I just make it a point to pad using rags or a piece of heavy leather underneathe the cross piece that holds the wheel down and under the pry bar.
