Hi all,
I recently picked up a 96 80 series with a bad head gasket. I have just recently tore it down and the head is off at the shop now. Unfortunately, when removing components and draining the radiator, there is hardly any coolant in the system, its ALL oil.
Obviously, I need to try to get all of this flushed out. Are there any useful tips to going about this? I don't really want to get the nice clean head back on before I do the flushing, but looks a little difficult to get the block flushed out otherwise?
I think I can manage the heater core flushing using the inlet and outlets on the firewall and clamping some hoses to them. The radiator might be a little trickier as plugging the large ports is a pain?
I did get the water pump cleaned up and the thermo housing, but still have the remaining 3 sections to do.
Also, on another subject, I'd like to clean up the oil coated lower engine as well, to be able to monitor for any leaks after its all back together. What do you guys find is the easiest oil remover off the exterior engine surface?
