TIFU when I.... (1 Viewer)
Denver, CO
.... replaced my rear suspension height sensors ('07 GX).
Bone heading it, I figured I'd pump the rear up to Hi to max access easier. Then swapped out the sensors doing a fairly good job of marking the existing before disassembling.
Now it seems to drop down onto the bump stops every time I turn the car off, but I've not been able to find any leaks on the bags or the lines do the bags or the lines to the compressor so far
So I'm thinking, hoping, that maybe this is as simple as when I installed the new sensors they thought they were at a normal height setting, when in reality the truck was pumped up to Hi.
Any suggestions on the best way to fix this? Yes, I did do searching, but the results didn't really address this kind of goof up.
If it’s at the right height when the truck is running I think an air leak is more likely. Have you tried soapy water on all the connections?
