On a recent wheeling trip a rogue rock attacked my tie rod and left it with a 10 degree bend and a broken spirit. The steering on this rig was never spectacular so I took the opportunity to replace the whole set up.
Luke from 4x4 labs. set me up with 1.25x.219 wall 1018 DOM threaded tubing, and some GM 1 ton tie rod ends. We decided to flip the tierod to the top of the steering arms from added Clarence.
Removing the old parts was pretty straight forward; the only special tool you may need is a pitman puller, and a convincing hammer to beat the old tie rods out of their 20 year homes. A well placed blow and the ends should fall out.
For the new GM ends to fit I had to reem the arms from the top. Snap-on makes the tapered reemer you need part # r121. Setting up the drill press took some time. Using lots of cutting oil, the reemer made short work of the arms.
The new drag link didn't have the hole for the steering damper so I picked up a rancho version r5404 (I think) and a bracket kit.
Did an alignment, took her for a drive, adjust drag link, another drive, another adjustment and that's all.
Anyway here are some pics.
