Counting threads or measuring rod protrusion will only get you close. It's easy enough to do an alignment once the new rods are in that I wouldn't even bother to count anything in disassembly.
That thing looks amazing but I don't really want a to drop all that $$$ just to clean a few rods. I have a friend who has a garage full of tools and was able to get an angle grinder. It looks like I can just buy a wire wheel for that and it will work about the same?? Do I need to clean all the gunk off first (old dirt + grease) or will the wire wheel do that for me?Also the rods have little brackets on the ends with bolts-those twist a little bit but won't come off....should they slide off the end? I'll try to get some pics tonight before I clean them.
You can walk into 100 old shops and get 100 different ways of doing the same job. It is going to be what works best for them. Then you have to think about what the average Joe has in their little garage and Taylor your answer to what they have to get the job done. I have all sorts of tools that I could use on this very job. But I Taylor my answers to what I figure the person has and knows what to use. I learned how to turn wrenches in the 70's. What worked back then still works for me on basic stuff. This is the reason I do not answer a lot of questions anymore on here. Too old school for most of you.
A good point ... just don't want to wear out tires getting to the alignment shop.
I would still count the treads and then use string or dental floss for the alinement
http://www.circletrack.com/chassistech/ctrp_1204_determining_wheel_alignment_string_your_car/
more hardcore version:
http://www.hotrod.com/techarticles/chassis/hrdp_0411_wheel_alignment_guide/viewall.html
I did this on my FJ40 after putting on tire rods and then got it alined. It was spot on. Maybe I got lucky.
Ok, now I am starting to get a little freaked out about using that grinder. My friend also suggested buying a wire wheel for my drill-said it would take much longer but would work. Is that what you are referring to or just a hand held brush? I have one of those and tried to brush off a little area and quite honestly, that did almost nothing. Anyone in Raleigh have a blast cabinet?![]()
RThe City of Raleigh appreciates the work you are doing. We're only as good as the weakest link...
All the little stuff helps newbies like me to save some time and headaches and is so appreciated!The real question is: How'd you like those shelves?
Also, Laura is awesome, Johnny is merely tolerable.![]()
Those tie rod ends cleaned up nice, didn't they? Glad I could help![]()
Those were quite nice, can I order a set for my garage?![]()
