...Tire shops don't bat an eye when asked to work on them.....
x 2
I've never had a tyre shop in NZ (when I used to use them) mention anything about safety risk (or use a safety cage either).
When these toyota split-rim wheels are in good nick I believe it would be next-to-impossible to have a "ring" fly off.
However "heavy rusting coupled with a brainless tyre-fitter" may have caused a statistic or two - probably in very primitive parts of the world - that some people will cling to in order to condemn them. (I know of no specific injury/death cases involving un-molested genuine-Toyota-landcruiser split-rims in any part of the world though.)
...They usually take a lot of weight to balance........
This is exactly what prompted me to remove my rubber liners/pads. They are very heavy and I have found that they were responsible for my wheels needing balancing weights.
But my wheels are hot-dipped and I would not have tried this if they weren't. (My thinking here is that the liners are mainly needed to protect the tubes from rusted/rough steel and from rust flakes.)
I've been running liner-less for about 3 or 4 years now and I admit I did suffer one puncture. But I traced that to a manufacturing fault in that BFG tyre. (It had a split in the inner wall that I had never noticed before and this split had pinched the tube - which wouldn't have happened if I'd had a liner fitted - but only because of where the split was located.)
By the way, the 750x16 tubes are available everywhere where there are trucks operating. (So it is hard to imagine anywhere in the world where you can't get them readily.)
But of course I have to protect the area around each valve stem and I do this with a heavy-plastic washer that I made myself. (Without these you'd actually see some of the tube-surface exposed around the valve stem.)
And I also squirt a bit of silicone sealant (RTV) in the gap in the "ring" to stop anything damaging getting to the tube that way.
But I'm not recommending running liner-less to others - As I say - It is just an experiment I'm doing that enables me to run much lighter wheels while experiencing no steering shimmy (or any other ill-effects) despite not having my wheels balanced.
But I may just keep the experiment going indefinitely
