I might make it. Good luck either way! I don't know if this is standard practice, I always pulled the distributor and primed the oil pump with a drill.
rusty_tlc said:If you haven't done it already don't forget to put that battery on a charger, you've been using it a lot testing lights and stuff. It might not hurt to have a back up in case you have to crank the engine for a while.
With help priming the PS shouldn't take long. I had to jump back and forth between filling the reservoir and cranking the wheel back and forth so it took me a while, but still not that long. It's one of those things you will have to check every time you drive for a while to make sure you account for any air that burps out later.
DesertLake said:Did you try the new sensor?
I called Howell and talked to troy there. He asked about the check engine light. Told him when keyed on it's lit. When cranking, it goes out.
He said that is the problem. When cranking, the power is shutting down to the ECU.
So... Gotta re wire the power to the ECU.
It's all RUSTY'S fault!! Lol!!!
locrwln1 said:Makes sense, I didn't think the CEL wasn't working right. Hopefully it is an easy fix and you can get it figured out.
Jack
Yeah right... You guys all bailed and left me w/ half a keg!! Pussies!!
half a keg????Yeah right... You guys all bailed and left me w/ half a keg!! Pussies!!
Krusty Krab said:Ya, my limit is 4 pints. Root beer that is.
Thanks for the Pizza and veggies! Glad to hear the beastess started. That kind of stuff/problems keeps me up nights. Your taking her out sunday? Bronco in the PM? I might be up for that!
