This May Be A Stupid Question
Well,,,,yea ,,,,ya can . . .
but you'd end up with 4 speed ( or 5) reverse, one really low speed forward . . .
plus, the oil would drain out of the breather hole :-)
cool,
but it is stupid.
what i was thinking, you could rotate the housing, still have the carrier mounted the same way with some mods to the housing,like where the ring gear runs thru the housing, would have to cut the notches for the ring gear.
breathers could be welded shut and redrilled
:idea: :confused:
What are you doing now?
yes you can...
It takes some mods but it will work..
Mace said:
yes you can...
if anyone knew what i was talking about it was you!!!!!!!
you'll see doc.
i pulled a chevy 350,sm465 and a np205 t-case out of a donor truck.
well, the t-case output is driver side.
i originaly wanted to keep the toy t-case, but all the adapters out there are for 2wd sm465's
was thinking about flipping the rear axle to drivers side and using the np205 t-case. :idea:
well after a couple of PM's being sent and talking with woody,i think the thing to do is run a older toy t-case behind the 4wd sm465. as per woodys tech on the sm465 ;)
thanx woody :cheers:
you really want to go to a weaker tcase than the split???
You ever hear of a 60 tcase splitting in half?
2wd sm465's are easy to find
impossible...the rear output on a 205 is centered.
There are LOTS of centered rear diff options, and a nice link in the Tech Links that covers a bunch of them....all will give you added rear strength and allow you to keep the exisitng 465/205 combo.
no i dont, woody just sent me a pm about that
a guy in town has found me one,he'll give it to me if i buy the AA kit from him $430.
could be the way to go!
ANYONE NEED A SET OF SLIDERS? SO I CAN PAY FOR THIS! ;) :D
i have lots of time to figure this out.
tell you what, I have a spare lc housing. I;ll send it to you if you pick up a $100 mini rear axle to make a hybrid ;)
I'm puritanical .. Chevy drivetrain with chevy Axles .. Toy drive train with Toy Axles, no troubles.
NP205 GM12 centered, all lockers options, gears .. and much more stuff .. :D
