I'm far from an electrical guru and I really don't want to mess with the trucks electrical system since it is all 24v and works well. I would rather put a secondary 12v system in place
Good approach.
To have 12V available you may just put a 24V-12V step-down converter. I did that to feed my 12V radio and the lighter socket for any necessities.
Most tools run USB ports today anyway, so I put a USB port assy in the center console, which directly feeds from 24V, though.
But this all sucks from the starter batteries, so I'm not running heavy equipment like a cooler on it.
For this purpose I also made a plan:
In a so called dual battery setup, DC-DC chargers are state of the art. They assure a controlled charging of the secondary battery, which works better than just a cutoff relay. In modern vehicles, the alternator is not providing constant power (don't know how that is called in English). Here a DC-DC is the only working solution anyway.
A 24V dual battery setup (actually 2x 2x12V) is quite expensive and bulky due to the 2 additional batteries needed. And most appliances run 12V anyway.
So going for one 12V secondary battery is a good alternative. But this requires a 24V-12V step-down DC-DC charger. VIctron has some and redarck most likely also has.
The difference between a pure step-down converter and a charger is:
A converter just provides whatever is drawn from it. No control. The fuse is the limit.
The charger is 'smart' and controls its output in order to provide the battery a decent charging. It has bulk absorption phase and settling phase as needed.
Victron actually literally has this in its product names: The chargers bear 'smart' in it:
This is what I would use:
The Orion-Tr Smart DC-DC charger is an adaptive 3-stage charger (bulk – absorption – float) designed for dual battery systems, such as in vehicles or on boats where the starter battery (hence the alternator) is used to charge the service battery. The name "Smart" comes from its built-in...
www.victronenergy.com
Regards Ralf
