Glad to hear youre keeping the AHC @Fuge. The spring rate for the AHC torsion and coils springs is a lot lower than stock non AHC springs. The OME are stiffer than stock non-AHC.
Swapping in tired non AHC springs into a rig with AHC is too stiff for a smooth ride without adding a fair amount of weight. (Tired= springs slowly loose their springiness over time.) It really comes down to how much weight you put on. You have a heavy list of future mods but my GUESS is that OME is probably still too much spring. Alot of the weight in AHC cruisers rides on the hydraulics. It just comes down to weight and maintaining an AHC neutral pressure within specs.
The good news is there several ways to fine tune your spring load and AHC anf keep every thing happy and funation ingredients well. You will need a Techstream ot similar OBD2 reader to read AHC pressures. The Torsion bars are a snap for the front, jusT need a big socket and adecent sized breader bar to make adjustments. The rear can become adjustable by installing helper airbags in the coils. (I'm adding air bags as soon as they arrive.)
The front bumper and winch recently installed added enough weight (180lb) that I need to reindex my torsion bars to get my front pressures down a little lower and perfectly to spec. Not new springs, just resetting the twist to get the adjustability into the right region of the spring. However, when I add a rear bumper and extended fuel tank, I'll most likely put heavier springs in the front and back, probably tired stock springs. Until then, my existing prings and airbags should handle all my extra weight.
