Yeah, that Kenwood looks about my speed. Are you going mag-mount antenna or something else?
From the recommendation of another member (Ramy), I went with a Diamond K400SNMO mount. Apparently this is THE mount for an 80 Series. It comes with 13 feet of very thin Teflon cable (RG316) that makes routing very easy. It mounts to the upper hatch on my 80 and the tiny connector and cable was able to fit through the weather stripping with a teeny hole. I had to disassemble and reverse the mount to make the cable exit on the correct side as I wanted the mount on the driver's side of the hatch for routing reasons. No big deal.
For NMO mount antennas, I got a 1/2 wave Diamond that folds NR770HNMOB, but here in the northeast it is likely to get destroyed by trees. I purchased a 1/4 wave Diamond NR72BNMO which is nice and low and still gives decent performance.
The Diamond stuff is expensive but seems to be very high quality. All said and done my setup was $300+ with 2 antennas, which I probably don't need.
I mounted the radio where my CB used to be on the back of the center console, but this unit is small enough to fit below my single DIN stereo. I may wind up moving it at some point, but for now it's fine and smaller than my old CB.
I replaced my 15 year old giant Cobra CB with an all in 1 Cobra 75WXST that I found on
Amazon for around $80 with free shipping. The power supply and antenna connection are so small, it fits neatly under the shifter console.
At some point I'll snap some pix of the mount so you can get a better idea of what I'm rambling about.
In the meantime, I still haven't taken my exam so I can't use the damn thing yet.
