- Thread starter
- #361
If there is some wiggle room forward that might work, it’s definitely worth a try. I am going to pull those bucket seats tonight and set in the backrest if it will fit with the bucket tubing and see what it looks like.
I originally posted this on the FJ40/55 page and was encouraged to try hear as well.
Looking for all you smart folks to help me understand more about this hinge and get some pictures of the hinge in place. In it's natural environment so to speak.
A friend asked for me to make a replacement so I thought about machining it out of aluminum and adding a stainless steel shoulder bolt and oil impregnated bronze bushings.
Here is where I'm hoping you can help.
What years did this hinge come on? Only FJ55?
Is it for the back rest if the back seat?
Is this a replacement part people would...
What’s stopping you from cutting that left side loose, moving it back an inch or so to match the right side and welding it back into place?The only thing I can think to do is cut off the bottom leg and reweld it further aft, but that seems like it would be the wrong thing to do.
No, not dumb, just a matter of a set of fresh eyes on a problem.
Nice!!!What’s stopping you from cutting that left side loose, moving it back an inch or so to match the right side and welding it back into place?
Believe me, if you ever witnessed any of my thought processes, you would not feel dumb!Nothing, I just couldn’t see that as an option and feel dumb now.
I had a SBC with an aluminum intake. The distributor wouldn’t hold timing and slip off every so often. I’m sure part of it was that I was afraid to strip the threads for the hold down clamp. Tried a variety of clamps, but ultimately I carried a wrench and could get it close enough by ear and fix it properly when I get home. Ultimate fix was an LS, haven’t needed the timing gun in some time.It was super nice here yesterday and I couldn’t believe I have only driven the 55 to the end of the block and back three or four times since ownership. I really don’t know anything about how it handles the open road, but I know I have never made it further than the end of the block without finding some significant issue. I thought I would try my luck despite none of the wiring, lights, etc etc working. Well we made it to the end and turned around, it was running a bit hot and just not much there when I tipped into the go pedal.
I really haven’t done squat to to the engine so I decided to check the timing. Why would it not be correct? Well turns out 4 degrees is not enough for an sbc. Easy fix. All of a sudden this small block just came to life, throttle response was that snap I was missing and it sounded awesome. Idling in the garage the temps were much happier too (hopefully that maintains while on the road). It was raining today, hopefully I can get it out the next time it’s dry.
