The Knitting Circle
It has 2 pivot points so that I can lay the carrier almost on the ground. I am hoping this will make it easier to get those 37's on and off.
Sent from my iPhone using magic
3 x 2 x ??? tube?
That looks like 2x4
That would make sense why I thought it was 2x4 then. I was looking at the thinner side compared to the thick side
Calculations???? What are those? Are you talking actual engineering? Ain't nobody got time for that.
Yeah that sounds to much like work for me I'm out. :D
Like trying to decide if a C12 x 20.7 will span 23'-0" while crippled for a stair with 100lb load with a 1/4" deflection.
UHH, yeah.
.......What he said.
If you like that try " the rule against perpetuities" and see how you feel.
That's just how lawyers justify their salaries.
Write it so only we can decipher it and then charge a service fee for interpretation........BRILLIANT!
BDog. You get that crap unstuck?
Got it movin like a good dose of castor oil hit it!
OK, so I lifted the White Digger last weekend including swapping a set of control arms that already had the OME bushings in them, then immediately went riding later that day out at the WMA... Even had Mister Woooo check to see what the rattle from the front driver was... it was an odd knock that I had never really heard before (I've heard almost all and can usually tell you what it is...). But this one was a hard metal banging on a hollow metal... So I thought it was the exhaust maybe.
Meh, keep riding. Drove all week occasionally hearing this noise. Flat-towed to Morris Mountain. Set out to wheel and got a friend to look to see what the knock was... Back up, pull forward, back up pull forward...
"Oh, I see!... your control arm-to-frame bolt is missing!"
YEP! the driver side control arm was completely off the frame! LOL! The only thing holding that entire side together was the sway bar!
That's not correct. I wouldn't buy them if they offered them.
