Some 4runners use fronts, some use rears. Sounds like one will work in the rodeo, but you will probably get more lift than you want.
bhmmapping said:There is a trooper in the pull a part
Just jack up the front and tweak up the torsion bars. Not hard to do Matthew and I did it Saturday along with install new springs in the back of my 100
How much can you crank on tbars before you bend/break something? I already tuned it up an inch in the front.
Sent usin the "new" app.
probably why the rear is sagging.
if you are already up an inch in the front why not just grab the trooper springs for some stinkbug in the rear. that way you won't look so loaded down running contraband up 82.
I turned the front up when we installed new shocks all around and spacers in the rear. What I really need are stiffer springs of equal height.
zrheard said:I turned the front up when we installed new shocks all around and spacers in the rear. What I really need are stiffer springs of equal height.
Gotta have a beefy suspension to not raise suspicion with those kilos and dope money in te back...
I have to call BS on this without pics. This has been built up for too long to just mention it in passing.
zrheard said:Well you know with the good ol boys I want to keep a low profile. Having the out of state tags and all... Everyone knows not to drive in Alabama without state tags I guess we are living on borrowed time as it is.
You know what I got a ticket last week in the wifes out back..
