Should voltage regulator be tested as mounted in vehicle or bench tested.
We checked battery before starting and meter 12.3 volts. Started it up and still read 12.3 volts. Revved engine and held to fast idle and still read 12.3 volts. It has a new battery and had alternator checked 2 different places and it checked as good. Amp meter always reads to the left of center mark.
Attached is the current VR which is OEM and I believe correct for a '77.hey Tib ,
what part # voltage regulator are you working with ?
or
post a photo , if its aftermarket , or your not sure .........
i have ALL the FSM 's on the how , when , and why in regards to your
field bench test procedures , i can post diagrams here for you
best way is the OEM TOYOTA FSM step by steps ............
- the first , newer looking one , is a 27700-60080-84 , it covers 9/72-8/76
now toytoa disc. / NLA
- however , the old one below , is a old GREEN PLUG 27700-60100
8/'76 to 5/'78 Land Cruiser FJ40, also NLA / Disc.
- the person installed the earlier 60080 black plug , because green plug was disc. at the time ,
- i do not know , if the 60080 and 60100 are interchangeable , only barring a different plug ?
- but , the plug style change would suggest to me Very Strongly that they are Indeed
different in some significant way , otherwise why the plug change ?
both plugs are NON-WATER proof , or un-sealed , i know this fact
there is , IMO , a VOLTAGE REGULATOR expert here on MUD that will know this
answer in super HIGH tech Facts , his name is RUDY .......
let me dig up his MEGA regulator thread in MUD advance search , and return to post in shortly
