Haven’t read much on gturbo specifically for the 13bt but I’ve read up on the green wheel. This may be a nice option. I may be getting one sooner than later due to the nice exchange rates.
Note - Different actuator orientation to the picture supplied.
www.gturbo.com.au
Long time no see Alika!
From munro racing out of australia:
This is an Upgrade to the Toyota 13bt Ct26 Turbo to increase efficiency and flow with quicker spool.
The turbo was fitted from Toyota back in 1985 being too large for a 3.5 ltr 4 cyl deisel. Generally suited for a 4.0 ltr 6cly so mostly a laggy setup.
Working with what we have I changed the stock 8cm Turbine housing to a 7cm and fitted a much more efficient and reliable with more flow Billet compressor wheel and ported Turbine housing and Adjustable actuator set with higher pressure.
Brings this up to something closer to how it should be.
This was an email exchange we had:
The 13bt ct26 use a large 12ht turbine housing which is too large for a 4 cylinder diesel engine. I fit a small A/R turbine housing along with an upgraded billet comp wheel and other tricks which dramatically improve responce and less laggy. Although the heat sheild needs to be redrilled to mount back on.
20 psi is ok with the upgrade billet compressor wheel although if you want to go over 25psi it will need a larger high flow compressor wheel.
Although unless the engine and fuel system is built for it that will be risky.
Price for this upgrade is $1440 Aud$.
Also can do exchange if yours is stock and genuine toyota or yours can be done. I will need a zip code for freight cost from Brisbane, Australia
munro racing turbochargers
Also Wink4x4 does some great mods on the 12HT turbo's, says he has a great mod for the 13BT as well, shares the sentiment that the current CT26 isn't the best match for the 13BT.
from Remy:
Ye, we have! The 13BT engine is quite rare here, but however it is
been done to put a wink turbocharger on one of them. I've developed a
wheel to suit the 13BT quite nice and can make a lot of power
depending on the tune.
Regards Remy
Wink 4x4 - Engineered Performance
Also found this:
Lets you bolt a Garrett GT2052 to the manifold
CustomFabShop.com | Custom Automotive Fabrication
