- Joined
- Feb 27, 2002
- Threads
- 10
- Messages
- 135
The Ranger IS the adapter between the gm engine and the Toy tranny. The Mark's or AA or Downey adapter is one pathway to adapt, as in,
5.7 GM motor-x , y or z bellhousing Adapter-Toy Tranny (with either GM or Toy clutches)
OR
5.7 GM-Ranger-Toy Tranny
OR
5.7 GM-GM tranny (auto/manual)-AA adapter-Toy transfer case
As a side note, maybe the gearing situation is something that you arent aware of. At some point you'll want to regear the f/r diffs to match the tire size you have now. Just like starting up a hill in second gear makes little sense, likewise running big tires with the stock diff gears. Remember the size of the stock tire? it was a 28-29 in street tire. What you've got now is roughly a 15 percent OD in every gear, making it harder to get up to speed, and once there making you think the truck is slower than actual 'cause the speedo is only accurate with the stock tire size. When you read 70 in the speedo, you're probably going 80. Now the truck IS a dog with the 2F, but it wasn't built with a motor for freeway cruising in mind, but rutted beat up dirt roads in some far corner of the world. To make your 60 more freeway friendly you may swap the motor out, but unless you dot the is and cross the ts with the install of the FI motor, the mileage will suck (less than 10 mpgs) and That will sour you on v8s real fast. Keep researching the topic, thre's guys here that have sweet setups, that have power AND economy, looks AND function, boobs AND Brains, er... what was the question....?
cheers
OR
OR
cheers
