Wanted Tan/Oak sunroof plastic surround
Need the plastic sunroof bits for a tan/oak interior for a 97. Thanks
If you are referring to the interior sunroof plastic trim, tan new one has been discontinued, used one are mostly brittle. Mine cracked and rest on the sunroof shed. The grey one are available, spray paint and install away.
I have a truck I'm parting out. Can you send a pic of what you need
@ccslider There are 4 pieces attached to the glass frame that cover the bolts. I only have the rear one. Need the two sides and front or all 4. They can be hard to remove without breaking the tabs
Ok cool thanks for the picture. I'll pull the headliner down and see if I can remove them without damaging.
Yes very very brittle.. I tried on two different sunroofs. First one broke so on the second one I was super cautious and still no luck. I will not attempt ever again on that trim.
i part out 80s all the time and finding one in good shape, that can be removed, is harder than finding a good condition clamshell for the 91-94 steering wheel.
