Just wondering if anyone has any experience with this, I am out of town and pollen is getting crazy. My wife is home alone and wondering if she can take it to car wash.
to fold the outside mirrors in before entering. Lower it or turn off radio....3 weeks ago I took my LC thru a autowash, wife turned on radio while inside, now its bent/broke to ****....gotta figure out how to fix it
I'll just say that I recently installed this antenna I bought from amazon after a car wash mishap. I wasn't paying attention and had my mind on other things and forgot to shut off the radio before I entered. I realized it was still on and the antenna was deployed half way through the auto wash. The replacement fits great after trimming the white plastic geared portion to the correct size and reception is good as well.
OEM was $45 I think, my buddy who replaced the antenna in his 100 pointed me to this one for $20.
As long as the gear strap didn't break off inside the motor it's not hard to fix. Unscrew the top ring, let the motor run up and before it hits the stop, pull firm up on the antenna and it should feed it out for removal.
Installation similar to removal, let the antenna motor run down, and insert the plastic gear in the hole and feed into the motor (I think teeth face towards rear doing this). And reinstall top ring.
If antenna broke off in motor, you'll have to remove motor through fender well and disassemble.
If, like me, you're in the boonies, be aware that FM likes an antenna ~30" long, AM as long as possible. It sounds to me like the antenna needs some lubrication (I use silicone spray applied w/ a paper towel), or perhaps the nylon gear strip or the mating gear inside the motor is stripped...you want to hope and pray it's the antenna.I think I am ok I can hear the motor run and the antenna goes up n down but only a few inches..
I was thinking about swapping out to the TRD stubby antenna, but not sure how hard that is to swap
I had never thought of that before. Although if she is taking my LX to a car wash, I don't think shell be up for getting the leaf blower out. hahaA wet truck attracts more pollen, get the leaf blower out![]()
just to clarify, your antenna's don't retract all the way in. Mine leaves about 6-8" out in the down position.
**hoping this makes sense.
