bjowett said:
Another option - since there is a pump in the rear housing, a cooler could be fit. Not sure how easy it would be, probably would require a couple of holes be drilled/tapped and maybe a pipe plug or two.
That is a interesting idea but deeper than I want to go for now, already have a lot on my plate, it would also increase the T-Cases gear oil capacity, that would also help with fluid deterioration
robbie said:
THe pump is used for pushing lube through the center of the out put shafts that hopefully not plugged up. every one I have opened has been plugged, needing a good cleaning. These holes allow the fluid to go on the other side of the sealed bearing (do not totally understand the need for sealed here), and maybe to keep the seal area cleaner and the bearing cooler?. it is a small thing but may help the center diff live longer. I will look at the diagrams here shortly and see if a cooler may be added. later robbie
Do you think these are plugged up to so bad that they do not flow at all or just have build-up on the walls of the passage but still flows? If they are still flowing then hopefully good clean lube can slowly clean them?
How deep do you have to go to check for this? Can you pull one of the extension housings off and see it?
Rookie2 said:
RT-
I've been using Delo in the diffs and M1 in the t-case. I'd be interested what you found in the front. Have you done a front axle service yet, or are you still getting some contamination after doing the front axle job??
Thanks,
Rookie2
Don’t think it has anything to do with the Delo, from the way it held up in the rear diff (color wise and very little junk on the magnet)
I did a birf repack shortly after buying the truck, I am getting heavy grease contamination of the gear lube, the stuff that came out of the front diff was a runny version of diff soup, and unlike the T-case and rear diff there was some foam in the fluid (I had just driven it) and the magnet had more metal and of larger size than the other 2 gear oil cases, I don’t think my front diff likes gear oil/grease mix
So far no gear lube in the knuckles (RT knock’s on wood repeatedly) so not all hope is lost, just this weekend I did the breather mod, maybe the flapper on the breather was cause low pressure in the diff to drag grease in from the knuckles and hopefully now the different lubes will stay where they belong, like IdahoDoug found, if it is contaminated again after the breather mod I will have to go back in to the knuckles to at least replace the oil seals maybe more
landtoy80 said:
When my t-case failed it was a heat issue. It would get so hot you couldn't even touch it.
It took 3 to 4 hours to cool enough so the VC to unlock. That was after I took a hose to it some time between hour 3 and 4. IT WAS HOT.
When I drained and took it apart the flund was M1 was clean and internal parts show no sign of being to hot (no blue balls ..... in the bearings)
Was the VC overheating the T-case or was something else in the T-case overheating the VC? Did you ever get to the bottom of it? IIRC you got a new T-case from Toyota?
