Pulled up next to a 2012 (the black 200) and noticed I'm a good 2 inches shorter. Bad photo but take my word for it. Is that time taking its toll on the suspension or a difference between the years?
I have an 08 as well. The newer models (don't know when / year this started) come with a 3/8's spacer that is fitted on top of the front shocks.
I ordered one pair from @beno and it gave me a bit more height. PM Beno of you are interested in learning more about this spacer - its cheap and easy to install if you have a stock set up. I had to notch out a section of the (added) spacer so that it would work with my Icon external resi fitting - the fitting comes out of / off of the top of the coil overs and was fighting for space with the new spacer.
there's one explanation for you. Gravity and years is probably the other half of that height difference that you are noticing.
thanks
thanks
I know it is not a surprise for you but 3 tone car will sag over time , especially this one, you lucky if all 4 spring will sag at the same time , people complaining that they sag one side looks bad from the side one side is lower that other.View attachment 1113622
Buddy, measure from the center of the hub to the fender. post what you get. most of the guys running 35s (willy, MSCruiser) have posted before and after numbers. IIRC, they were starting at around 20~21" in the front and went up to 24 ish... I checked mine when I got it and was at 19" in the front. shocks fade, springs sag....gravity sucks!
Part of what I love about my 100 is having the OME suspension installed at 120k miles and 8 years old. Like a new vehicle. My LX570 not to concerned about aging suspension, way more robust then the LX470 and most off them are still working.
You don't have to sell me on the virtues of AHC, I drove a 2015 LX570 for six months before buying my LC. I went back and forth debating both suspension systems. AHC is incredible and honestly, I miss it, but ultimately I knew that I wanted to significantly mod the truck, so I went with the LC.
Sounds like you have the best of both worlds.
Wow, this was enlightening in many ways.
Measurement results:
DSF - 19.25"
PSF - 19.75"
DSR - 20.5"
DSR - 21"
So it looks like I got sagging and lean.
I just installed an OME kit from Slee and ended up gaining 3-3.5 inches at all four corners. I was concerned until I read this post. I never considered the sag would be so dramatic over time.So, I suppose if I was intending to put a 2.5" lift on and upgrade the suspension, I'm really talking about 4" ( ~1.5" getting back to stock height then the additional 2.5" lift) plus any additional height gained from moving to 33" tires. Make sense? Just trying to determine how tall the truck will actually be after the refresh. I'll work on that lean during the process as well.
